Construction bracing steel structures during erection
Does anyone have suggestion regarding published standards on temporary bracing for steel structures during erection work..
r
r
RE: Construction bracing steel structures during erection
Dik
Also Robert Ratay has an excellent text Handbook of Temporary Construction.
I'm sure that other guidelines exist say by the AISC for example. And the IBC also.
That said, bracing in construction is usually left to the contractor with the design engineer specifying that that steel members shall be braced during construction/erection until all final steel pieces are in place.
In the case of bridges steel girders must be braced until the deck concrete has set.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
