balancing drum and balancing disk
7
On a turbine driven boiler feed pump what is the function of a balancing drum with a balancing disk?  on prints it shows a balancing drum leak off line that goes back to the pumps suction...
can anyone provide some expertise?
RE: balancing drum and balancing disk
7
In any centrifugal pump, each impeller tends to produces some amount of thrust because of different pressures and different geometries on the two sides of the impeller. In a high pressure multi-stage pump (such as BFW) the number of impellers is high, thus the net thrust would be large unless something is done to balance it out.  The two main ways to reduce the net thrust are to oppose the impellers or to use a balance disk/drum.  For axial split pumps, it is usually most economic to oppose the impellers.  About half of the stages are oriented with the suction pointing toward the coupling and the rest are oriented with the suction toward the thrust bearing.  The thrust of the stages pointed in opposite directions tend to cancel out.  The net thrust that the thrust bearing must take is much smaller than it would be if they all pointed in the same direction.
But axial split cases tend to have an upper pressure limit.  At very high pressures, barrel pumps are used since they can handle the very high pressures better.  With a barrel pump, it is much more difficult to find a good way to direct the flow path through a set of opposed impellers.  So instead, they point all the impellers in the same direction and use a balance disk or drum on the end.  The balance disk is just after the last stage so it has full discharge pressure on one side.  A line is routed from the other side of the balance disk back to the suction.  The size of the drum is made so that it provides almost as much net thrust as all the impellers combined.  Area times pressure difference between suction and discharge equals thrust force.  Since there is a very high pressure differential across the balance disk/drum, it is critical that the clearances are correct or else excessive flow will be diverted back to suction and the thrust balancing force will be lost.  In other words, if the balance drum/disk fails, a thrust bearing failure is likely to follow.
The difference between a balance disk and a balance drum is whether the primary pressure drop is taken across a radial clearance (drum) or an axial face (disk).  Some pumps use a combination drum/disk that incorporates both radial and axial
JJPellin - nice answer,worth a star
Yup.  I've heard that term before and never understood what it was. Now I think I have half of a clue what it means.  Thx.
JJPellin,
That is surely the most coherent explanation of these devices that I have ever seen.
Ditto, I gave a star several days ago, but the following occurred to me.
JCP, have you considered making this an FAQ?
rmw
In Flowserve WDE, WDX and others there is either a single balance ring /drum assembly or a stepped ring drum assembly.  As JJ said you simply apply reverse hydraulic force opposing that being created by each impeller stage.  The balance line return to either the suction side or to the point of origin is to keep down the chamber pressure at the stuffing box.  Packing or Mecanical Seal will only seal up to a given pressure.  You have to keep the chamber pressure at reasonable levels.  Some pumps dump back sometimes to the 2nd or 3rd stage depending on the initial suction pressures.  Installation contractors have been known to use these Balance lines as pump recircs.  I had one customer that only had a problem during boiler start-up. The pumps cavitated like crazy.  I found that the Balance line was used as a recirc back to the DA.  Problem was the pumps required 23gpm minimum continuous flow. During start-up the pumps were dead-headded frequently until steam demand.  Customer redirected the balance lines back to suction and installed recirc orifaces and problems went away.
