Importing assembly - joining of parts
I have a problem. I imported assembly with few parts to Abaqus, and some of parts have to be joined (to form the same deformable solid). How can I join different parts keeping them as volume partions, so I can later get structured mesh?
Thanx for any help!
Thanx for any help!
RE: Importing assembly - joining of parts
Otherwise, if you just have one volume (cell) you can use the many partitioning tools to subdivide the cell into multiple structured/sweep meshable cells. (There have been many improvements made in V6.6 to sweep meshing that make it much more forgiving to your topology)
For those of you who think you've exhausted the partitioning options (even though there are quite a few), there is a nice trick you can play:
To partition a cell, you can actually create a shell feature (extruded, revolved, lofted, etc) and look at the dialog box before you finally create it. There is a check box to say "keep internal faces". This will have the effect of "partitioning the cell. I find this particularly useful with the shell loft when the shape of the partition you want to make is quite difficult...
Finally, as one more bonus:
You can actually make multiple partitions at the same time. Just try it with extruded shells (sketch a whole bunch of circles to create extruded "tubes". Use the "keep internal boundaries" checkbox, and watch what happens!
I need one more advice. How to solve incompatibility between regions? When meshing some partitions I get warning message that incompatible mesh (incopatible element shapes) will be created. It is transition from structured to free meshed region.
