Draft computation mode
Draft from cone of draft from square? This option is available to PartDesign Draft operation. Something similar is found in GSD - Swept surface - linear - with a draft direction.
Does anybody know anything about the difference between the two?
RE: Draft computation mode
the square option can be used to avoid the problem where the draft angle is greater than an inclined neutral face.
