Wind effect on noise propagation
Hello All,
Does anybody have a formula that would enable me to calculate the attenuation upwind of an noise source due to wind speed and distance? Similarily, enhancement of the noise level downwind.
Andrew
Andrew
RE: Wind effect on noise propagation
For example, some years ago I learned that the noise level upwind of an exhaust pipe (when the wind is impinging directly on the open end of the pipe) is greater than the noise downwind.
Beranek has a plot, but the testing on which it is based seems rather obscure.
However no wind field is uniform. In particular, the wind speed usually increases with height above the ground ("vertical wind shear"), and this effect tends to "focus" the sound waves onto ground-level points downwind. Similarly it also tends to "unfocus" the sound waves away from upwind ground-level points.
The severity of the vertical wind shear depends upon many factors, including the roughness of the terrain upwind of the point in question.
