Change Mate Distance
Ok, so far I'm learning Solid Works by teaching myself. Right now that's my only option until I can get some training. I have figured out how to assemble components in an assembly but not how to change the mate properties after I have assembled them. For instance I mated two plates and specified a distance between their faces. Now I want to change this dimension but I can't figure out how without deleting the one plate and re-inserting it. Any help would be appreciated.
Ken Johnson
Ken Johnson
ITT Corporation
RE: Change Mate Distance
In the Feature Manager, you'll see a 'Mates' folder. Simply RMB on the mate and choose edit. Depending on what version of SW you're using, there will be a 'Mates' folder under each part as well.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Just double click on the mate and the distance dimension should appear on screen, then double click the dimension and change it.
... or RMB click on the mate and select Edit Feature
cheers
