Metal Temperature Color Chart
I'm heating a part made from 8620 steel for a shrink fit assembly. At around 400F the part starts to change color.
I'd like to be able to track its temperature by its color and without depending on the oven's gage.
I heard from some coworkers that there is a chart for steel that gives you a temperature range in the part based on its color. I searched the web but could not find "the chart". I came across some tables but they are for higher temperatures. Does such a thing exist? Thanks.
RE: Metal Temperature Color Chart
http://www.threeplanes.net/toolsteel.html
And another, more general chart:
htt
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Tempil has a nice phase chart for the hot colors: http://www.tempil.com/PDF/Basic_Guide.pdf
ht
I would suggest buying a tempil stick or two as well. We use a Tempil stick to train as to exactly which color is proper.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
