IGES WIREFRAME TO SOLIDWORKS??
I would like to import a wireframe model from SURFCAM into Solidworks.
Anyone know how well it works?
Any speedbumps I should look for?
Guy G.
Mechanical Designer/Drafter
Tucson AZ.
RE: IGES WIREFRAME TO SOLIDWORKS??
I heard rumors that SW wouldn't import wireframes.
I'll take your advice about the sketches
Guy G.
Tucson AZ.
Time for a Scotch!
Have to make do with a beer
Guy G.
Tucson AZ.
I have it in IGES, SCPRT(surf cam),and RPT.
however when I import I get a message "file contains free curves/points which are not desired according to import options. import anyway".
Problem: it gives me no opportunity to alter the import options.
Prob. 2: If I try to import the SCPRT file I get the "locked or incompatible type" message?
Prob3: the RPT file gives the locked message also
When I do import the IGES with the curves I get a clean wire frame HOWEVER I would like to import as a solid ( Or at least sketches as THE TICK suggested)
Guy G.
Tucson AZ.
SolidWorks can't create a solid as there is not a closed volume of surface entities to make a solid from.
You will also not get automatic creation of sketches.
It is a wireframe, pure and simple.
Assuming you have a prismatic wireframe model, I believe you can use the wireframe to create surfaces. Then when you have a closed volume of surfaces you can create a solid when you knit the surfaces together.
Is your package of SurfCAM capable of generating surfaces? If you create the surfaces in SurfCAM, then export those surfaces to SolidWorks you may have an easier time of creating a solid in SolidWorks.
Anna Wood
SW07 SP2.1, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
WD Raptors, 1 Gb network connection
http://designsmarter.typepad.com/solidmuse
