(Un)define element size "on Curve"
Hi all,
When needed one can adjust the element size along a given curve. The software puts small dots along the selected curve, indicating the (local) mesh size. So far so good.
But sometimes one needs to un-do this action. And if the command has been issued way back in modeling history (or before saving the model, rendering Ctrl+Z impossible) one can't undefine the mesh size on that curve back to default. Or is that possible? If so how?
Thanks in advance.
Alexander
Thanks in advance.
Alexander
RE: (Un)define element size "on Curve"
The key is that once you have defined sizing, it expects something to be there. If the dots or numbers bug you, just go View options- curve mesh sizes and uncheck the draw entity box. The visuals for the formating will dissappear but the latest formating will be there in the background
Carlo
