Another Grip Question
I have a load of entites on a dawing format which are in a named group.  How do I get them into a object list so that i can manipulate them as a group?
(must have killed to many brin cells over xmas!!!)
Cheers in Advnace,
P.............
RE: Another Grip Question
First you have to find the named groups so you have to cycle the database with the command MASK/15 set as that will only allow groups to be selected.  As you cycle you can check for the desired name using the &NAME command and then once you have the named group, you use the &GENT command to extract the members of the group.
That should get you started in the right direction.
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
