How far should steel be kept away from MFDC weld guns?
Does anyone know of any guidelines that may exist as far as how far steel should be kept away from this type of welding.
We are experiencing magnification of steels within proximity's of the MFDC weld guns.
As I have experienced before typically, the material has to be “inside” the loop area to inductively heat but I’m not sure of what the character of the DC field “outside” the loop area.
Any assistance on this matter would be greatly appreciated.
RE: How far should steel be kept away from MFDC weld guns?
What is "magnification"? Do you mean expansion? Which dimensional changes did you measure? Of what steels are you talking?
http://www.welding-advisers.com/
