searching for a configuration specific custom properties in SolidWorks
Good day everyone..
Is it possible to search for a configuration specific custom property in SolidWorks 2007?
We did some tests using SolidWorks Explorer 2007 to search for a configuration specific custom property, but it did not work. It was able to search for "regular" custom properties, but not configuration specific custom properties. Is this is a limitation?
If this is a limitation, has anyone found a work around ? For example a possible work around would be to be able to search inside a Design table for the Configuration Specific Custom Property (e.g. $prp@description).
Best regards,
Joseph
RE: searching for a configuration specific custom properties in SolidWorks
FYI...
Just heard back from the reseller, and this is a limitation.
If anyone knows a good work around, please let us know.
Have a great day,
Joseph
Joseph,
You can use a macro to list the custom properties for a configuration. File custom information is stored in the document file. It can be:
General to the file, in which case there is a single value whatever the model's configuration
- or -
Configuration-specific, in which case a different value may be set for each configuration in the model
This is documented in Solidworks Help under Help/Solidworks and Add-Ins API Help Topics.
Here's an example from the Help file:
CODE
This example shows how to list the custom properties for a configuration.
 LIST CUSTOM PROPERTIES EXAMPLE (VB)
' Preconditions: SolidWorks document is open to which custom properties have been assigned.
' Postconditions: None
Option Explicit
Public Enum swCustomInfoType_e
    swCustomInfoUnknown = 0
    swCustomInfoText = 30       '  VT_LPSTR
    swCustomInfoDate = 64       '  VT_FILETIME
    swCustomInfoNumber = 3      '  VT_I4
    swCustomInfoYesOrNo = 11    '  VT_BOOL
End Enum
Sub main()
    Dim swApp                           As SldWorks.SldWorks
    Dim swModel                         As SldWorks.ModelDoc2
    Dim vConfigNameArr                  As Variant
    Dim vConfigName                     As Variant
    Dim vCustInfoNameArr                As Variant
    Dim vCustInfoName                   As Variant
    Dim bRet                            As Boolean
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Debug.Print "File = " & swModel.GetPathName
    vConfigNameArr = swModel.GetConfigurationNames
    ' Is empty if a drawing becasue configurations not supported on drawings
    If IsEmpty(vConfigNameArr) Then
        ReDim vConfigNameArr(0)
        vConfigNameArr(0) = ""
    Else
        ' Add a blank string for the nonconfiguration-specific custom properties
        ReDim Preserve vConfigNameArr(UBound(vConfigNameArr) + 1)
    End If
    For Each vConfigName In vConfigNameArr
        Debug.Print "  " & vConfigName
        vCustInfoNameArr = swModel.GetCustomInfoNames2(vConfigName)
        If Not IsEmpty(vCustInfoNameArr) Then
            For Each vCustInfoName In vCustInfoNameArr
                Debug.Print "    " & vCustInfoName
                Debug.Print "      Type     = " & swModel.GetCustomInfoType3(vConfigName, vCustInfoName)
                Debug.Print "      Value    = " & swModel.GetCustomInfoValue(vConfigName, vCustInfoName)
                Debug.Print "      Text     = " & swModel.CustomInfo2(vConfigName, vCustInfoName)
            Next
        End If
        Debug.Print "  ---------------------------"
    Next
End Sub
Hope that helps!
Shawn Oelschlager
Production Control Ass't
Transco Products Inc.
http://www.transcoproducts.com
SolidWorks Office Premium 2006 - SP4.1
Pentium 4 (2.8 GHz) - 2GB RAM
What exactly are you attempting to do?  Do you want to check open documents for a certain config-specific custom property, or do you want SolidWorks Explorer type functionality?  That is, do you want to be able to search documents without opening them in SolidWorks?  This can be done using the undocumented API calls in SwDocumentMgr.dll.  The .dll is distributed along with SW.  Prior to SW'07 the use of this .dll requires a "license key" string.  This can be obtained free (for use inside your own company only) upon request from SolidWorks API support.  Starting with '07, this license key string is not required.  Any value passed as a key will be ignored.
These .dll functions can be called from any program (Excel, etc) that uses OLE automation.  Below is sample SolidWorks macro that will list all the custom properties for each configuration of the active document.  Note that these will be read from the stored file on disk rather than the current version in memory, so if you add a new custom property you will have to save the document before the macro will find it.  For this macro to work you will need to go to Tools->References in the VBA editor and check the box for SwDocumentMgr 200(x) Type Library.  You may have to browse or search for it.  Mine is located at C:\Program Files\Common Files\SolidWorks Shared.  If you are using SW2006 or earlier you will have to get a license key string and change the value of the constant "DOCMGRLICENSEKEYSTRING" to whatever key you receive from API support.
CODE
Const DOCMGRLICENSEKEYSTRING As String = "Replace this text with your license key string for SW<2007"
Dim swDocMgr As SwDocumentMgr.SwDMApplication
Dim swDoc As SldWorks.ModelDoc2
Dim myTestConfig As SwDocumentMgr.SwDMConfiguration5
Dim CfgMgr As SwDocumentMgr.SwDMConfigurationMgr
Dim myCfgNames As Variant
Dim myCustPropNames As Variant
Dim myCustPropVals As Variant
Dim myDocMgrClassFactory As SwDocumentMgr.SwDMClassFactory
Dim myDocMgr As SwDocumentMgr.SwDMApplication
Dim mySwDoc As SwDocumentMgr.SwDMDocument7
Dim i As Long
Dim j As Long
Dim msg As String
Sub main()
Set swDoc = swApp.ActiveDoc
Set myDocMgrClassFactory = CreateObject("SwDocumentMgr.SwDMClassFactory")
Set myDocMgr = myDocMgrClassFactory.GetApplication(DOCMGRLICENSEKEYSTRING)
Set mySwDoc = myDocMgr.GetDocument(swDoc.GetPathName, swDmDocumentUnknown, True, Empty)
Set CfgMgr = mySwDoc.ConfigurationManager
myCfgNames = CfgMgr.GetConfigurationNames
msg = "There are " & CfgMgr.GetConfigurationCount & " configurations of " & swDoc.GetTitle
For i = 0 To UBound(myCfgNames)
    Set myTestConfig = CfgMgr.GetConfigurationByName(myCfgNames(i))
    msg = msg & vbCrLf & vbCrLf & myCfgNames(i)
    myCustPropNames = myTestConfig.GetCustomPropertyNames
    For j = 0 To UBound(myCustPropNames)
        msg = msg & vbCrLf & "  " & myCustPropNames(j) & " : "
        msg = msg & myTestConfig.GetCustomPropertyValues(myCustPropNames(j), swDmCustomInfoUnknown, "")
    Next
Next
MsgBox msg
End Sub
Thank you Shawn and Handleman, we are looking for SolidWorks Explorer "enhanced" functionality.
We could use the API, but would like to propose a less time consuming solution. So we might just create a database or spreadsheet instead and use it to store and search for information.
Joseph
