Flow Control - Pressure Regulation
Hi All,
I am working on a farm-scale ethanol plant project and have a question regarding flow control. Our reflux apparatus consists of a centrifugal pump and a flow control valve. The pump generates 60psia upstream of the valve. The downstream pressure is 15psia. Not wanting a 45psi pressure drop across the valve, I sized the valve for a 5psi pressure drop. Now how do I get a d/p of 5psi? Should I put a pressure regulator before the control valve to drop the upstream pressure to 20psia? Or should I put a backpressure regulator after the control valve to raise the downstream pressure to 55psia? Assuming I am even on the right track, I would rather use a backpressure regulator downstream of the control valve because I happen to have one on hand that would work.
Thanks in advance,
Newgeer
Thanks in advance,
Newgeer
RE: Flow Control - Pressure Regulation
You should have no problem selecting a control valve to handle the full pressure drop. However the capacity calculation for the control valve should consider the minimum pressure differential. Thus you still need to know the other pressure factors.
But the real answer is to evaluate system hydraulics as suggested by JLSeagull. This seems odd to have a pump producing so much head.
Please provide more details about your system and the pump. There are many ways to improve on your system and more details will help us guide you.
What do you mean by "minimum pressure differential"? Should the pressure drop be more than 5psi? Do you see any other areas of concern, from the information I have given you?
You will use an instrument to measure variable that you want to control and then you adjust the valve opening accordingly.
No matter what the system will be limited defined by your boundries.
Best regards
Morten
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
BigInch
It appears I tackled the problem bass-ackwards. I should have selected a valve based on the available pressure drop. Instead I am trying to alter the pressure drop to work with a valve I already have.
The dP is defined by your system, and your required flow rate. If you are conserned that your valve may be damaged by the dP then you must look for another valve. On occation several valves in series may be required in order to "distribute" the dP - but thats another matter.
Best regards
Morten
If your pump makes 60 feet of head (26.01 psi, if the fluid is water) and the pressure downstream of the valve is atmospheric, then the differential across the valve is 60 feet. What is, is. If you try to run the valve open enough to only make 5 psid, then the only way to do that is to have the pump sooooo far out on its curve that your're probably into pump runout and you will be flowing a lot more than your design flow.
If your valve is oversized and won't control at such a low flow corresponding to the pump curve at 60 feet, you might stick an orifice in the line downstream of the valve
to take some of the drop.
I don't think it will make that much difference.
The valve alone will need a Cv of about 0.48.
If the valve is taking only a 5 psi drop, the valve will need a Cv of 0.71. The orifice will need a Cv of 0.653, which is pretty close to 10 x 1/16" diameter holes.
Those calcs assume you really meant that the pump discharge pressure is 60 feet absolute, but is am suspicious and believe the pump pressure is 60 feet GAGE ( 40.7 psia) but in that case if the valve was the only restriction in the system the Cv of the valve would need to be about 0.376. SO with all the manipulating of the pressure drops the Cv still hasn't changed bt a factor of 2.
If you are using a 1" valve with a reasonably typical wide open Cv of 14 and also a reasonably typical equal percentage characteristic, the valve would be running about 8-10% of stroke. Not optimum, but in this case it would not be damagine either---just poor control resolution.
The actual cure is to open up the pump and chuck the impeller into a lathe and to reduce the diameter of the impeller so that it will only MAKE about 8-9 feet of head at 1.6 gpm. Pump literature will show pump curves for different diameters.
BigInch
BigInch
I still believe that your pump output is 60' GAGE, but correcting for SG of alcohol, and assuming 1/4" trim, I get a Cv required of 0.30 at 1.1 gpm, and 0.41 at 1.6 gpm. This should put you just about mid-stroke on the valve.
Newgeer
