PDMlink automation as it interfaces with Pro/Engineer
Has anyone who has or is in the process of implementing PDMlink been able to increase Pro/Engineers functionality vs as compared to using Pro/e with Intralink.
I have been tasked with creating a wishlist of increased automation between Pro/e and PDMlink. Below are a couple of examples I came up with and I was wondering if some of you had more. Any websites would help as well. Thanks!
3.1.1    Part numbers assigned to all fabricated and commercial off the shelf (COTS) are requested from the Drawing and Database Number Request Tool(DAD)imbedded in PDMlink. The part numbers would be linked to PDMlink and assigned to the pertinent PDMlink attribute values and the Pro/engineer part and assembly parameter values.
3.1.2    All DAD tool inputs relating to pertinent program attributes (contract number, etc) are automatically assigned to the “CAD document” within PDMlink.
3.1.3    The DAD tool attribute values assigned to PDMlink are dependent on which type of part was assigned a number i.e. fabricated or COTS.
3.1.4    Access all military and commercial specs from within the PDMlink browser.
3.1.5    Specifications and related information associated with the COTS part documentation is retrieved from all  pertinent vaults including the “Military and Industry Standards Part and Vendor Database”. The associated documents are displayed in a GUI and the option to retrieve or dismiss each related document is available at the time of part creation.
3.1.6    PDMlink has the ability to cross-reference the  supply chain for manufacturers and suppliers based on the type of fabricated or COTS part being specified. A GUI would appear with multiple options for pre-selection of pre-filtered vendors of choice from its approved vendor’s lists. This would relate to some of the function that parts engineering had in the past.
3.1.7    Any attributes with multiple value options are displayed in a pull down menu for easy pick and place.
3.1.8    PDMlink knows it is a fabricated part being created and prompts the user for materials/density and finishes via a comprehensive list of each in a pull down menu.  This would be an optional approach to material and finish assignments and Pro/e material and finish assignments would remain the second option.
3.1.9    PDMlink is the only tool for adding Pro/e attribute/parameter values to parts. Standardizing this process would eliminate the ambiguity between Pro/engineer parameter input and PDMlink attribute input.  Possibly eliminates the need to designate and undesignate.
