Tree item names disappear while approching with mouse pointer.
After CATIA V5R17 was installed on workstation (Inter 965RY with Video card on bord , Intel Dual Core Duo 1.86, Kingston 1G\800MHz ) I was unpleasantly surprised.When I point any tree item with mouse (WITHIOUT CLICK, BUT POINTING ONLY), the item becomes orange, as it supposed to be, but its name always disappears. If I click the item, only then it becomes orange with white item name inside. If I point any object on solid or sketcher or any other item on the screen, the same phenomena is seen on the tree- orange rectangle without item name inside.
What is the solution? Is any of my hardware can be a cause ? For example- Intel Dual Core Duo 1.86 ?  The same CATIA soft with the same Windows XP, SP-2 work pretty well at another workstation.
Thanks a lot.
RE: Tree item names disappear while approching with mouse pointer.
video on-board?!... I´m pretty sure that´s the reason...
