High Voltage DC to Low Voltage DC Converter Help
I am designing a HV (450 to 950 VDC) to LV (24 VDC) converter. I am having problems creating the controls for the switching transistor and choosing the transistor. The schematic is a standard buck converter with S being the transistor and sensing from just before the inductor. I would also like to try and squeeze a transformer in there to isolate the 24 volt line from the HV line. Any help would be appreciated.
RE: High Voltage DC to Low Voltage DC Converter Help
The control circuit should be pretty standard.
Sometimes I only open my mouth to swap feet...
