How to select nodes on a surface area
I am modelling  loads on cylindrical surface area and need to select nodes on this area. Does anyone know how to select nodes on area ??
RE: How to select nodes on a surface area
select the area, then issue
NSLA,<selection method>,<selection option>
where:
- <selection method> is s (select from full set), r (reselect from curent selection), a (add to current selection), or u (unselect from current selection) as usual
- <selection option> is 1 (all nodes on surface, including shared boundaries) or 0 (only interior nodes of surface).
Thank you very much..I used following commands if anyone wants to review it.
asel,s,area,,68,, ! Selects Area-68
nsla,s,1 ! Selects node on this area
