Devices to measure pressure in a building?
Can anyone out there recommend a device for measuring the pressure difference between the outside environment and the inside of a building? I was told to look at Magnehelic gauges but i'm not sure which range of pressures to get.
-J
RE: Devices to measure pressure in a building?
If the building exists, rig up a quickie water manometer and measure the actual pressure difference.  Buy the Magnehelic with a range just larger than that.
Without transducers or alarm contacts, Magnehelics are pretty cheap.  I'd buy a size up and a size down, too.
Mike Halloran
Pembroke Pines, FL, USA
You can gauge how much pressure by noticing how hard the doors are to open. Negative 1 inch of water gauge will make a door hard to open. It is like having an inch deep of water in a pan setting on a horizontal door and trying to open it. Unless you have a lot of fans drawing air out of the plant I would bet on 1 inch water gauge or less.
