Saving a .cgr file as a .igs file
I have a .cgr file I would like to save as a .igs file. How is this done?
I tried inserting the .cgr file into a .CATProduct, but when I save the .CATProduct as a .igs file, the .igs file is empty.
Can anyone help? TIA
RE: Saving a .cgr file as a .igs file
Derek
This case with CGR i have brought up to DS attention but nothing really happens. Even our DS resorces don't have a better solution then using STL, so we use that basicly to get information to our styling department regarding packaging, kinematics and ergonomics.
If somebody has an other approach how to make CGR usefull outside the DS sphere I'm also interested.
Here's the work-around I finally ended up with. I used the simplification function under DMU and saved the simplified file as a .model file (instead of a .cgr file). I then opened the .model file and copy/pasted the .model solid into a CATIA V5 .CATPart file. I could then save the .CATPart file as a .igs file.
It's kind of a pain, but it worked. Thanks for all of your help.
