Belt Conveyor Calculations
Need some help getting there.
I know what I want,but dont know how to get there.
Conveyor is:
dirt/earth 100lb./cuft. G.S.=1.6
speed= 0-400fpm ( must throw 7')
22' long
5' wide belt
19 degree incline
35 degree trough idlers
330 prw belt,pintle chain (maybe)
(will be dumping from truck in hopper to conveyor)
(useing hydraulic)
Need:
drive roller dia.& no.?, motor no.?
Conveyor is:
22' long
5' wide belt
19 degree incline
(useing hydraulic)
Need:
RE: Belt Conveyor Calculations
Go to gearmotor manufacturer websites and get their technical manuals on how to size their gearmotors. Those docs will have formulas and examples. Some companies even have online sizing calculator programs that you can use.
seweurodrive.com
dodge.com
eaton.com
nord.com
TygerDawg
http://www.dolphin-ds.com/beltconv1.php
If you also want to use the conveyor to 'throw' the discharging material then this is a function of belt speed. I suggest this is checked with conveyor design handbooks published by CEMA in the USA or MHEA in the UK.
