glued plywood to use as rafter
So I have this curved roof and it looks like the easiest to frame this is to use (2) 3/4" plywood nailed and glued together to create curved rafters. I only need probably 4-5 rafter at this particular location of the roof. What value can I use? Is it conservative to say it is D-F 2x12 #2 (I tell them to cut it 11.25", so it will have the same area as 2x12 so I can use the same hanger).
RE: glued plywood to use as rafter
http://w
www.SlideRuleEra.net
