Pro Program, how to add/remove or suppress/resume subassemblies ???
I'm designing a conveyor with 3 subassemblies, the first is the head and it's a fixed length, the second is the mid section with a fixed length of 10 feet and the third is the tail section with a variable length that depends of the conveyor length.  Right now, I have a pattern of the mid section of 10 feet and the overall conveyor lenght is driven by a parameter. The relations change the pattern number and adjust the length of the tail section depending on the conveyor length.  Now, I would like to change that so pro-e could add/remove or suppress/resume one or more mid section subassemblies according to the conveyor length.
Anyone can help me to achieve this ?
RE: Pro Program, how to add/remove or suppress/resume subassemblies ???
We have discussed this isuue several time on this forum. Do a search or see the following threads:
thread554-100210 and thread554-24772
the second thread explains how to swap components frim the same family table.
Good luck!
-Hora
Hi Hora, thank you very much for the info.  I tried it and it worked perfectly.
