Graphite coating on steel surface
I whould like to know the process of graphite coating on steel surface.And i want the equpiment details to start a graphite coating unit.
 Thank you.
RE: Graphite coating on steel surface
You can use Plasma Vapour Deposition PVD or Arc Evaporation to coat carbon onto steel surfaces.
The full scale equipment is relatively expensive, but the small laboratory units can be used if the parts are small.
