Heat Transfer Coefficients
Where can I find a website with thermal conductivity of materials? I'm going to attempt a basic analysis of the heating requirements of an airplane so I'll need conductivity, radiation, etc. One of those one page lists is not nearly extensive enough to locate all the materials I'll be using.
Roger
Roger
RE: Heat Transfer Coefficients
The reference books on thermal conductivity of materials are edited by Touloukian-Ho, Purdue University. See the vol. 1 and vol. 2.
Otherwise, look for trough the following gate:
http://www.mayahtt.ca/tmwiz/default.htm
Follow the instructions to come in to The Thermal Wizard where you'll find out the databases:
Metals
Non-metals
Air
Gases
Water
Liquids
Other Libraries
Pay close attention to the reliability of technical data coming from manufacturers and dealers.
Recently I've found out the Appendix on Thermophysical properties (very detailed and updated) on Lienhard's e-book
at:
http://web.mit.edu/lienhard/www/ahtt.html
If you need more detailed data there are very large databases where the access is available by fees.
I'm sure, the collegues in the forum, will point out to you others useful links on this subject.
Regards.
Gianfranco
http://www.matweb.com/
