Variables in patterns.
I am trying to develop a pattern of simple rectangular protrusions.  What I need to do is have each instance of the pattern slightly longer than the one before it, based on a formula.  The overall length of the pattern is variable driven as well.
Is this possible with the pattern along curve tool?  I think I know the answer, as I have tried this, and it appears that variables are not applied to instances in a pattern.  That said, any suggestions on how I could accomplish this task?
Thanks.
RE: Variables in patterns.
what you are trying is impossible with a pattern. A pattern of an
item is only a shortcut to place that part manually at different
places. It is in fact always the same feature or part. So a change
on the master feature/part will affect all patterned items.
To get what you want you succeed by pattering a construction surface
On the surfaces you may place your protrusions which now can be
changed individually because they are unique.
To have a surface patterned on the x/y plane draw a short line on
either the y/z or x/z plane. the line should be colinear to the
horizontal axis. Then extrude that line symmetric to any width.
Now pattern this surfce either circular or rectangular.
HTH
dy
/Edit
One other approach may be this one (easy):
- draw your rectangle and extrude it to the minimum height
- now pattern this extruded item.
Then use the Modify --> Modify Face to adjust the height which
can be done on each individual item. Just pick the top face
and move it. The amount moved is stored in a variable and
thus can be adjusted by a formula
To accomplish this you must have SE V17
dy
It is possible to pattern these occurences, but it's not very easy, and the bottoms should be on a solid.
So the way to do this is make the first protrusion upside down (on a parallel plane) and make it extrude to next (which should be the solid which is your baseplane).
Then make a curve which contains the variables you need (length and height change). Pattern the feature along this curve, since they extrude to next the length will vary.
Difficulties of course are: Make the curve follow the right path, make the steps the right distance (try it, it's not easy).
Hope it helps, IJsbrand Schipperus
Hi IJsbrand,
interesting approach -- never thought of that. I posted a
simple example here (I hope I got it right):
Var-Pattern
dy
DY,
that's exactly the pattern I created. I was just to lazy to upload the sample to this forum!!
IJsbrand
Thanks for the suggestions!  The modify faces worked exactly as I needed.
Tim
