weight of different wall systems??
does anyone can give me a reference on the weight of different walls systems or a website with this kind of information?
thanks a lot
RE: weight of different wall systems??
Quite a broad question.  What kind of walls?  Masonry?  Depends on the thickness and grout spacings.  Metal stud w/plywood?  metal stud w/EIFS?  Wood stud?
If you are looking for a general answer, then usually a wall that is not masonry is about 10 psf.
ASCE-7 also has a Dead Load list of wall systems.
