LOOKING FOR SUPPLIER THIN INSULATION 3/5 MM AUTO ADHESIVE ONE SIDE
I would like to find :
Thin insulation adhesive 3 to 5mm can be sticked one face after taking out protective paper to steel sheet.
Width 800 to 1200 mm delivered in rolls of 30 meters to 100 meters depending of production
Product searched is : ONE SIDE AUTO ADHESIVE +foam + external vapor barier similar a aluminium foild external and opposite side auto adhesive with safety paper that you take out when you stick on the metal sheets
Aluminium foild must be resistant because we profile the sheet when insulation is sticked ON FLAT SHEET
Used mainly for cutting sun effect and noise on metallic building roof
A suitable Insulation will be used by a hudge steel group worldwide where they manufacture steel sheet
French islands,Guyana, Dominican republic, Haiti, and so on
