Machining funnel shaped counterbore in ductile iron
For a 12 mm diameter hole in a ductile iron part, I need to machine a funnel shaped counterbore (inverted frustrum of a cone). The entry diamter is 24 to a depth of 3mm then there is 45 degree taper for further depth of 3 mm. As can be calculated, The outer diameter of the flat land is 24 - (2 x 3) = 18. The inner dia is the hole dia i.e. 12 mm.
The two fillets created have 0.5 mm radius.
Can you please give me some ideas on how I can have this machined on volume basis.
Thanks for your help !
RE: Machining funnel shaped counterbore in ductile iron
Are you saying that the cone is a 45 deg. one?  Couldn't you just use an ordinary metric countersink bit?
Don
Kansas City
