Pump discharge pipe
Pump discharge pipe
Folks, I'm wondering about the threaded rods (usually ~5/8 or 3/4 inch) that I often see on pumps' discharge pipes on vertical rises. The rods are connected to flanges on either side of a rubber boot/stop check assembly. There's usually one on each side of the pipe, external and parallel to the pipe. A nut at each end of the rod, if tightened, looks like it will compress the rubber vibration boot at the outlet.
I've heard the rods called "alignment" rods, but I thought they were to compress the rubber boot. Can any of you precisely explain the purpose of these threaded rods? I've seen these left loose on some projects, but instinct tells me they should be snug (possibly to prevent expansion of the rubber/flex boot).
Your thoughts are appreciated...
RE: Pump discharge pipe
Thanks!
Pete
P. J. (Pete) Chandler, PE
Principal Engineer
Mechanical, Piping, Thermal, Hydraulics
Processes Unlimited International, Inc.
Bakersfield, California USA
pjchandl@prou.com
Thanks again, -Chas.
