Sfor starters vs variable frequency drives
I’m trying to make a comparison between soft starters and variable fequnecy drives for a hoisting application – a 40 kW motor will be operating a vertical water gate through a warm gear driving two large screws. What would be major advantages/disadvantages of both options for the given application? Thank you for any advice.
RE: Sfor starters vs variable frequency drives
