Transformer Chain Link Enclosure
The utility I work for has several above-ground Transformer Chain Link Enclosures that house medium voltage (17 kV) switches, transformers, and cables.  All elements are rated for outdoor use.
Most of these chain link enclosures were originally installed in locations that had minimal foot traffic.  Over the years this has changed and now several of these enclosures are now in areas that receive significant foot traffic.  In a perfect world we would simply install concreate block walls in situations where the foot traffic has increased, but this is very costly.  Is anyone aware of any type of material that could be placed on an existing chain link fence that would function both to keep curious eyes away from the contents and to prevent a catastropic failure from injuring nearby people?
Thanks in advance for your assistance.
RE: Transformer Chain Link Enclosure
Arc Suppression blankets (Salisbury)
We had a fence contractor insert vertical vinyl plastic strips designed to fit into the weave of the fence's chain, and diminish the interior view of the substation equipment.
While the plastic strips did not totally block the view of the substation interior, it did provide increased privacy from prying eyes.
I doubt if these plastic strips will provide any protection from explosions, fires, etc.
Check with your local fence contractors to see what is available.
I consider utility style pad mounted equipment a lot more 'public safe' than similar metal clad gear etc.
Much of this is installed where accessible to the public with out ANY protection.
It is probably more expensive to change the equipment than to build a concrete block wall, but that has been my preferred arrangement where switches and transformers might be accessible to the public.
Remember that putting up barriers restricts airflow around the equipment, and that your transformers may be depending on the exisitng circulation of air to shed heat.
