Tangent mate not working
This is strange.  I've got a couple of "gears" (like cams) I'm working on--very wonky shapes whose profiles are best described with a spline (not elliptical, round, or regular).  I'd like them to touch at their tangent points--think of an ear-shaped extrusion--the curved surfaces of which I'm trying to make tangent to one another (two of these cam/gears).
When in the mate dialog box I get either Parallel or Perpendicular as options--not tangent.  Any ideas?  I'm quite confident I've done this sort of thing before, even if the extruded curved surfaces were built from a spline.  Perhaps I've got amnesia on how to do this?
And if that works, I'd like to create a gear or belt mate (if remotely possible) so I can move the cam/gears in relation to one another smoothly to test the motion they generate in my assembly.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
RE: Tangent mate not working
The only thing I have to add is that I don't like tangent mates because they don't work well for me.
Tangent mates won't work on spline curves.  Might want to try using a sketch overlay with a close fit arc.
If I create my curved surface with a series of arcs (real PITA to edit the curve to get my motion right), I'm concerned I won't be able to get my tangent mate to work with the consecutive tangent surfaces created by several tangent arcs on each face.  Is this possible?  (I figured it would pick a single surface in my curve created by one of the arcs and that would be all--I need tangency to the whole curved surface set, hence the spline idea.)
Jeff Mowry
If you end up having to use the series of arcs method, you may be able to use the Composite Curve or Path tools.
cheers
Thanks!  I'll check it out.  For the presentation tomorrow I went ahead and turned everything into gear teeth (won't move one another in SW), so I'll have to deal with this later.
Jeff Mowry
Can you create a "dummy" sketch to mate with, then hide it?
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
I could, but I think I'd run into the same problem of using either a spline or multiple arcs connected to each other (tangently) to get the curve I need.  I doubt that would work, would it?
Jeff Mowry
