Background drawing
Background drawing
What is the correct way to faint-out the background of a floor plan, so I can do the MEP plan on top of what I get from an architect. The file I get from an architect usualy has many layers and many colors.
I want the paper plot (in black & white) to have faint background and dark MEP lines.
RE: Background drawing
"Everybody is ignorant, only on different subjects." — Will Rogers
The XRef layers will all start with the name of the drawing so they're all grouped together, hence easy to manipulate all at once.
Of course, if your plotting is object based instead of color based then you'll need a different plan of attack (for which I can be of zero help)!
