BTU Calculation using % of elements (i.e. C, H, N)
I'm looking to find how to calculate the BTUs of a coal/coke sample if I have the %C, %H, and %N.  I know it can be done, but I can't seem to find the equation.  Thanks, and no it is not for homework, it's for my job.
RE: BTU Calculation using % of elements (i.e. C, H, N)
babybear:
From Perry's Handbook (equation 9-7, page 9-5, 6th Edition):
Q = 146.58C + 568.78H + 29.4S - 6.58A - 51.53(O + N)
Q = Btu/lb
C = wt% carbon
H = wt% hydrogen
S = wt% sulfur
A = wt% ash
O = wt% oxygen
N = wt% nitrogen
The equation was developed by the Institute of Gas Technology. The standard deviation for 775 coal samples was 127.
Hope this helps.
Milton Beychok
(Visit me at www.air-dispersion.com)
The following ASTM standards apply to calculating heating value:
ASTM D 3588 Standard Practice for Calculating Heat Value, Compressibility factor, and Relative Density of Gaseous Fuels
ASTM D 7174 Standard Practice for On-line/At-line Heating Value Determination of Gaseous Fuels by Gas Chromatography
I use the following equation from a book on natural and synthetic fuels,
HHV(kJ/g) = 0.3491*C + 1.1783*H + 0.1005*S - 0.1034*O - 0.0151*N - 0.0211*A
using weight % for C, H, S, O, N, Ash
It claims to be within 1.45% of tested results.
A note: most formulas apply on a "dry" basis. For measuring the HHV of coal/coke specimens use ASTM D-5865-04.
These are all helpful, we are going to use these, but does anyone know how to do the proximate analysis w/o the ash% in it?  Thanks for all your help so far.
Both ASTM D-5142-04 and D-3172-89 (2002) are test for proximate analyses. What's wrong with them ?
I'll have to get a copy of those.  We use ASTM C standards so I'll have to see if I can find a copy of the D standards.  Thank you
