317L Allowable Stresses above 850F
Are there any allowable stress values available to use 317L piping above 850F?
RE: 317L Allowable Stresses above 850F
The carbon is an austenite stablizer, so teh straight grade alloy is less likely to form sigma. Of course the higher carbon also will result in higher creep strength. The higher strength won't help if the material is brittle though.......
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
