Parallel Port Programming
I am making a device which counts bolt coming thorugh a detector, and all this is plugged into a computer using a parallel pot, but i need to find the means of communication with the parallel port and programming isn't my strong points, anyone able to help out on how i will need to communicate with it.
ideally i wish to have a live counter on a web page which can show the number of bolts going thorugh the device at any given time. otherwise a simple way of just counting them and diplaying once all the bolts is counted is sufficaint.
anyone able to help? anything will be appreciated.
Thankyou :)
Thankyou :)
RE: Parallel Port Programming
<nbucska@pcperipherals.com>
I have already solved a simmilar problem.
A production company wants to save a log of the amount of produced items in the main computer. A switch on the production line triggers a very simple circuit which is connected to the paralle port. Our program then saves the acquired data processes them in Excel.
I can make an ActiveX so you can easily use it in your web page.
If you are still intrested on the subject let me know.
senobars@yahoo.com
have photo sensor to trace the movement of bolt.
photo sensor can be connected to PLC
write programme for counting and store the value in a data register.
From PC write communication software to read the data register value of plc.
this can be done on serial port.
worked 100% effeciantly in the end :))
