HEC-GeoRAS: Convert XS 2D to 3D
I have the following problem. I created in HEC-GeoRas (V4) the required layers:
1. Stream Centerline
2. XS Cut Lines
I use a TIN as a DTM. It is no problem to create the required attributes (topology, lenghts/stations, elevation) for the stream centerline. Likewise no erros appear when I create the attributes (river/reach names, stations) for the XS Cut Lines layer.
But when I want to convert the XS Cut Line Layer from 2D to 3D, then the attribute table still remains empty. A message box appears with no text. This makes it difficult to find the error.
I know for sure that the cross section do not intersect and do not overshoot the baunds ot the TIN.
Does anybody has an idea?
Thank you very much in advance.
2. XS Cut Lines
