System Settings
System Settings
Looking for any advice/help on the following issues I am having. First one is that my toolbox has to be added in each time I start up. This is a local toolbox. Second problem is under system options, sketch, realitons/snaps - Automatic Relations keeps unchecking itself. Any ideas? Thank you in advance.
I am running SW2007 SP2.2
RE: System Settings
IN the add-ins of SW07 there is are 2 sides, one if for that session only (left) and the right is for Startup. If you have selected startup and you are still having this issue. Use the FAQ above.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: System Settings
