Non Linear Analysis Problem
We are having problems with running a non linear problem on Ansys. We have created a model in workbench and saved an input file. This is then imported into Ansys classic. Using 2 separate machines, on one machine the analysis runs right through to the last time step and converges. On the other machine the analysis fails part way through due to un-convergence. Is there any settings that might be set differently on the 2 machines.
thanks
thanks
RE: Non Linear Analysis Problem
I recently got a benchmark done of another FEA solver across a multi-processor platform I am thinking of purchasing. The same job ran on 1,2 and 4 processors OK but failed due to convergence problems when run on 3-processors. Not even the experts from the solver company knows why it has this anomoly.................
did you check that default convergence criteria are the exact same on the two environments?
Try eliminating the "/SOLU" part in the Workbench-to-Classical input file, and set up solution options directly in Classical. This might make some difference...
If you continue having troubles, please provide more info about the misconvergence messages: what is not converging? Force? Displacement? inside an equilibrium iteration or inside a timestep?
