bitumen emulsion plant
Greetings has anyone been involved in the design and or commissioning of a bitumen emulsion plant ??
RE: bitumen emulsion plant
hi we are "younis for emulsion" company and we are a specialist of emulsion plant construction and we have too emulsion plant in beyrouth lebanon. we do the assembling of emulsion plant and we have experience about the test of emulsion and formula.
                                              jean younis
Hi
I'am making controlsystem for Bitumen emulsion plant as well as PmB plant.
Banker
In the UK Cartem Engineering.
http://www.cartem.co.uk/pages/frame.html is a supplier of bitumen emulsion plant.
Formulation is often based on metered amounts of the appropriate components but asphalt and bitumen, bitumen emulsions etc. can also benefit from inline viscosity trim control. Most usually this is a continuous operation rather than a batch operation.
Meter blenders depend on formulating the emulsion based on a recipe and continuously blend the emulsion using ratio controller to maintain each flow in the correct proportion to the master stream.
Volumetric or mass flow ratios are both possible.
Viscosity is a useful indicator of quality and a final property so online viscosity measurement can be used for trim control.
Viscosity can also be used for heater control in spraying operations.
JMW
www.ViscoAnalyser.com
