eliminate duplicate records
I enjoy sql - but sometimes can't get my head around the puzzle;  Have Table1   due to sloppy data entry have duplicates in the Table1:
OrderID  Name  Address  Email
1       Joe    xxxx     123@test.com
2       Joe S. x xxx    123@test.com
3       Fred    yyy     456@this.com
4       Jim    zzz      ttt@you.com
5       Joey S x-xxx    123@test.com
6       Jimbo    zzz    ttt@you.com
The email field is being used as the basis of determining a duplicate and there is about 25 dups per 1000 records or so...(frequently more than 2 dups often up to 4 of the same).
It is presumed the higher OrderID value is the record to be carried forward.  Thus I need to return:
have been scratching around some sql statements for awhile and would very much welcome input from someone a bit more versant than I...thanks in advance....
RE: eliminate duplicate records
Depends on which SQL you're using. You will be looking for the syntax for TOP or LIMIT in the manual, and doing a query using ORDER BY DESC on the ID field
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
You might also want to see if "SELECT DISTINCT" may be useful.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
thnks both - but am still struggling....would welcome more input....
am thinking about this:
SELECT * FROM Table1 As X WHERE X.Email = Table1.Email AND X.OrderID > Table1.OrderID
but it will return only comparable records:
it leaves out:
because the OrderID is not > than any duplicate.....
and if I use >= it will return all records of the table
Found a relatively easy solution via 2 step;
SELECT Table1.Email, Max(Table1.[Order ID]) AS [MaxOfOrder ID]
FROM Table1
GROUP BY Table1.Email;
This gave me what I need because the nondups are by definition the max OrderID value of their group of 1...
The second step was just to join the full table with this where the OrderID were identical....
