Create Model from Cast Shape
I have a casting of the tops of two dies. They have been scanned and saved as a .sldprt file. The file is attached. I need to create models for the cast contours. I thought about offsetting surfaces, then deleting the attached file description but all gets deleted. What would be the way to do this?
TIA
11991
http:// www.mooloa d.com/new/ file.php?f ile=files/ 110107/116 8477215/26 045-DL2+HH +coin+impr int.SLDPRT
TIA
11991
http://
RE: Create Model from Cast Shape
I did as suggested. I zero offset the outside contour and the chamfer surfaces but when I deleted the "Imported 1" solid body, the offset surfaces were also deleted. I was not able to remove the surfaces in the "And all dependent items" area.
If they are "2 separate bodies" one won't delete the other.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thank You
Please re-read the above posts!
Thanks to All
