Component replace
Component replace
Component replace
In R14 when I do component replace from part_A to part_B
catia dosen't update te instance name, but leaves the old instance.
Product
- Part_B (Part_A.1)
Can somebody inform me if this is normal or it's a bug?
Rgds,
Damir
RE: Component replace
Hey Damir
I've used R13 and R16, and the Instance name still doesn't change. That would suggest it's normal, or at least a bug which they have a low priority to fix.
Craig
The best solution is to write a CATScript to rename all instances in a product. (to match the part or component name)
Catia Design|Catia Design News|Catia V5 blog
