How to make boss coincident with vertical wall?
Another newbie question. I've been trying to set up a coincident relationship between the vertical edge of a boss and a vertical wall (the inside of a shell). So far I can't figure out how to do it and instead I have to manually fiddle with the boss sketch center point to tweak the boss/wall spacing to zero. Is there any way to set up this coincident relationship parametrically?
A similar situations arises when trying to make the edge of a circle in a sketch have a concident relationship with a line in the same plane. It's easy enough to create the sketch, but the coincident relationship doesn't seem to be usable here. Any thoughts would be appreciated.
Thanks.
Thanks.
RE: How to make boss coincident with vertical wall?
Convert edges is a great tool to use when you want to line extrusions/cuts up.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
d94104 ... The direction of a Boss Extrude can be guided by an edge or sketch line. The option is the second box in the Direction1 section of the Extrude Manager. Just highlight the box then select the edge or sketch line.
