how to move part origin
Hi - I've been using SW for a couple of months and really like it. Unforunately, early on I created a model of a part with a bad origin (i.e. not centered). I'd like to fix this by moving the origin (or alternatively, move every sketch in the part the same offset simultaneously. I can't figure out how to do it. Any thoughts? Thanks.
RE: how to move part origin
Most commonly a base-extrude.
Edit Sketch and remove relations and reassign.
Hope this helps you.
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
Pete
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
