BOM TABLE WITH MULTI INSTANCES
Hi All,
Using wildfire 3.0
Can you make a BOM table in a drawing to report all QTY's in separate columns for each family table instance?  And still be live balloons?  Is there a work around other than manually entering?
Tofflemire
RE: BOM TABLE WITH MULTI INSTANCES
It's not clear what you want.  For every family table instance that appears in an otherwise 'normal' parts list you want a dedicated quantity column?  I'm sure I don't know how but if I were to look into it I'd start by playing with Column / Model Rep and, maybe, Filters.  Possibly concatenating tables.  All-in-all, especially with balloons, sounds like a nightmare.  `;^)
