Output feature - sketcher
Hi Everyone,
Sorry my english is poor :)
I have sketch (in sketcher).
I use OUTPUT FEATURE option. My sketch change. I would like raturn to normal profil (undo Output feature).
Thank for any help.
Michael
Thank for any help.
Michael
RE: Output feature - sketcher
Expand the tree to show all the geometric elements of your sketch, and then copy original Output Feature geomety (such as a line) and paste it into the same sketch. The result will be duplicate geometric elements (two lines), with one being part of the sketch and the other part of the sketch output.
If you no longer want the Output Features, then delete them after you copy & paste them.
PS: you're english is pretty good!
Thank You for yours quick answer.
I checked this method, it's good solution.
Is second method also.
Expand the tree to show all geometric element of your sketch (see Output icon into sketch tree structure).
Then we mast select oryginal Output Feature geometry and delete this geometry. The result will be "normal" sketch geometry.
If there is intelligible :))
Best Regards
Michael
