FEATURE CONTROL FRAME FOR COMPOSTE POSITIONAL TOLERANCING
Hi all,
Does anyone know how to double the feature control frame in geometric tolerancing to apply a composite positional tolerance. The double height frame needs to be attached to a single geometric characteristic symbol so I cant just add another frame. Thanks
RE: FEATURE CONTROL FRAME FOR COMPOSTE POSITIONAL TOLERANCING
If your in 2006 there's a check box withing the dialog box
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
Sorry to mention I'm on SW2005 sp5. Thanks
It should be pretty much the same. Try and look around in the dialog box. There might be tabs along the top or something.
Macduff spin
Colin Fitzpatrick
It been like that since I think 01... just need to start the next line and you will get a double frame.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks for the suggestions.
While I can add another feature control frame, it also adds (or prompts to add) another geometric characteristic symbol which is incorrect. The proper spec is a single symbol straddling the dual frames. Cant seem to get that.:/
Add the same character symbol as the line above and see if an option pops up to make it composite. There's a check box called "Composite Frame" that is greyed out until you add a second line. The check box becomes available when you add a second line with the same symbol as the first line. Now if your trying add a composite symbol againist the ASME Y14.5 standard, it won't be available at all
Macduff spin
Colin Fitzpatrick
Macduff
I missed the composite frame after adding the second line. Thanks much!
You're welcome sir.
Macduff spin
Colin Fitzpatrick
Thanks for the star swmetal!
Macduff spin
Colin Fitzpatrick
