Syntax message
Syntax message
I have a part (R14) that after using SMARTVOLUME in one formula I receive below message, (only the first time that I open this part in session).
Formula is very simple smartvolume(pad), so I think that shouldn't be any errors in the formula.
I would like to know the meaning of this message?
Rgds,
Damir
RE: Syntax message
RE: Syntax message
http:
RE: Syntax message
RE: Syntax message
RE: Syntax message
[img http:
RE: Syntax message
[img]http:
RE: Syntax message
RE: Syntax message
[img http.....jpg]
The imageshack gives you few links, have you used the one below:
Embeddable Code: + forums
RE: Syntax message
Derek
RE: Syntax message
Here you go, Jim...
Catia Design|Catia Design News|Catia V5 blog
RE: Syntax message
RE: Syntax message
