Mindmapping software?
Anybody use mindmapinf software?
I used to use MindJet but i havnt used it for a while (partially due to not having installed the software on my new PC
) But can anybody recommend other packages?
Best regards
Morten
Best regards
Morten
RE: Mindmapping software?
I've used the "mind-mapping" (which I liken to linking digital post-it notes together to form something with meaning) technilogy to write outlines for scopes of work. It's much more "free" than scheduling/PM software.
Also, you can write movie screenplays with Novamind.
http://www.nova-mind.com/
HTH
I use mindmap a lot for not taking, minuting and brainstorming an idear. Outlook, access and those other programs that you mention are for totally different purposes.
I newer use it for presentation for others - only for my self. Mostly because a lot of people seems to have a "block" against such things and i dont want to shove it down thier throats.
I just sometime find it easier to use software instead of a hand drawing.
Best regards
Morten
I like the mind maps for preliminary scoping and brainstorming - which is where it's appropriate. I've tried doing mind-mapping type stuff using Excel and such, but most of the time is spent sizing text boxes and getting the callouts to look right; NovaMind does that stuff automatically. I took a look at the Aibase website and that's an application that looks pretty darn good. I'm going to check out the demo.
Best regards
So therefore i dont use it except for my self (and tend to hide them a little
Best regards
Morten
http:/
http://sourceforge.net/projects/freemind/
